Question for the Gm techs
Old 10-08-2007 | 08:48 PM
04silverado's Avatar
Default Question for the Gm techs
The other day, i plugged up a scan tool to my 04 silverado with a 4.8. It didnt power up, and the guy at the auto parts store said this was typical of silverados. Didnt think anything of it, went about my business. Well today I got my hypertech 3 programmer in. Went to play with it, and sure enough, it does not power up. I checked my fuses, as it said in the troubleshooting guide, and found the cigarette lighter blown. It also said to check the accesory circuit, which i was not able to locate. Checked a few other fuses, but there was too many too pull tonight. Still will not power up, any ideas?
Old 10-09-2007 | 06:07 AM
Argon's Avatar
Default RE: Question for the Gm techs
the lighter fuse powers the scanner.maybe it blew again
Old 10-09-2007 | 06:34 AM
That was the first thing that came to mind, so i checked it. the fuse was still ok, but i need to ohm it out. Ive seen fuses look good, but still be bad. What pins on the diag port supply power and ground?
Old 10-09-2007 | 10:43 AM
Argon's Avatar
i',m not sure without looking it up...but there is only one12v pin
Old 10-09-2007 | 04:01 PM
ok, i checked the fuse with my meter, sure enough, looked good, but was bad. replaced it, and it went to working.
