Rattling or Metallic Noise at 3200 RPMs
Old 03-30-2015 | 01:21 AM
MRC Chevy's Avatar
Default Rattling or Metallic Noise at 3200 RPMs
I posted a while back about a transmission noise, but I was mistaken. The noise has nothing to do with the transmission.
Today I was able to recreate the noise in park at 3200 or higher RPMs. It's not all that troublesome or shocking, but something's definitely wrong. I'd say it's a squeaky high-pitched sucking, scraping or rattling sound of some sort.
The sound seems to come from the engine side of the firewall, somewhere in the vicinity of the glove box or lower.
Is something in the Exhaust Manifold wobbling? Catalytic converter? Any other ideas?
Old 03-30-2015 | 08:59 AM
SlimJim's Avatar
Baffles do come loose in mufflers and converters but the sound and occurrence may be different on every one. Can you get a long screwdriver and probe with the handle pressed against your ear? May not be doable in this situation but it works many times.
Good luck.
Old 03-30-2015 | 09:46 PM
primem's Avatar
if you have a pre 2006 vortec; check the exhaust manifold studs. they break and at higher engine speeds the exhaust leak will whistle past the gasket.
Old 03-31-2015 | 06:58 PM
That sounds like it could be your culprit to me
90bronco351
05-18-2009 10:19 PM
screamingijit
11-21-2008 02:51 PM
quadzilla200
07-12-2008 08:40 PM
jcormier89
13
06-10-2008 06:03 PM
94CHEVYON4S
02-06-2008 09:46 PM
