Rear End Gear Ratio
Old 10-17-2011 | 12:26 AM
alan7407's Avatar
Default Rear End Gear Ratio
Trying to figure out my gear ratio. For every turn of my tire, the drive shaft rotates 2.25 times. However, I've never heard of a 225 gear ratio.
Can anyone help me out.
Old 10-17-2011 | 02:25 AM
NullHead's Avatar
Look at your RPO codes to find out for sure. What year truck do you have?
Old 10-17-2011 | 11:34 AM
alan7407's Avatar
2002 1500 2wd. I looked at the RPO codes and it says GT4, meaning a 3.73 rear end. I guess I just don't understand how they get that.
Old 10-17-2011 | 08:21 PM
RUFFNECK4LYFE's Avatar
What RPM's are you at on the highway at 70 mph steady?
Old 10-18-2011 | 10:16 AM
alan7407's Avatar
About 2,000
Old 10-18-2011 | 10:04 PM
Wiked's Avatar
well do you have an open or posi rear?
on mine i had to hold one tire steady and spin 1 tire 2 times and count the driveshaft revolutions and i got my 3.73
Old 10-19-2011 | 09:45 AM
alan7407's Avatar
Well, if that is the case, then I probably have 4.50 (4.56?) gears. Doesn't matter, I'm going in and having them changed out to 3.73 today. I'm sick and tired of reading 85mph when I'm really doing about 72. And it should stop my ABS light from coming on.
Old 10-19-2011 | 11:11 AM
NullHead's Avatar
Wow sounds like you've got a whole host of issues there.
Old 10-19-2011 | 10:22 PM
alan7407's Avatar
Ok, took it in and had the gears replaced..............problem solved. Speed matches speedometer, and no more ABS light.
I wish someone would have told me earlier about simply rotating the tire and counting how many times the driveshaft turns. Since mine turned 2.25 per wheel revolutin, just multiply that by 2......equals 4.5 (or probably 4.56). NullHead, Thanks again for the assistance.
alconk
10-07-2010 09:43 PM
Old International
12-17-2009 08:12 AM
hounddog
07-06-2007 09:59 AM
MrLM7
04-19-2007 08:00 AM
karac johnson
08-21-2006 03:51 AM
