removal of stock exhaust
For those of you that didnt want to cut your stock exhaust pipe to get it out.... how did you get it out? Jack the body up a little to create room by the rear axle, then take the whole system out from the rear? If all else fails, would a tailpipe cutter do the trick?
when i switched my friends stock exhaust for my blowmaster i took his out and put it in my truck by removing that crossmember that is held in by two 15mm bolts and then unbolted the exahust of the y pipe and removed it from the hangers and it slid right out, but i had a lift to use iunno if it is possible with jackstands, you need a lot of room.
felix arrizon
18
04-27-2007 12:14 AM
