Removing wires from spark plugs
I have a 2002 silverado 1500 5.3L v8. I was planning on changing my spark plugs, when I tried to remove the wire from the plug I could not get it off. I tried squeezing to see if there was some sort of clamping device, nothing. I tried pulling as hard as I could, nothing. does anyone have any suggestions?
Thanks
Thanks
You need to twist them while holding onto the boot
Then pull them off
I use my hand so the boot does not get punctured
If you were pulling them by the wires
I'd replace them, you may have damaged the conductor wire
Buy OEM wires they have very little resistance
and fit like a glove
I just finished swapping mine out as well
The truck idles awesome
Then pull them off
razor2006
07-08-2008 11:35 AM
SC_Chevy_Lover
05-06-2007 11:36 PM
