reverse lights
Old 06-28-2009 | 11:25 PM
RJ86's Avatar
Default reverse lights
I was adding external back up lights on my 03 silverado and forgot to ground them and shorted out my primary reverse lights. i checked the fuses and the bulbs and they are all good but the primary reverse lights still wont come on. any ideas
Old 06-29-2009 | 02:09 AM
dmccartyfan's Avatar
Did you disconnect the externals and still the primaries don't light? How did you wire the externals? Are they in series with the primaries or? If they're in series the entire circuit must be complete from one end to the other. Also, wiring them in series MAY (and I could be wrong) cause too much of a voltage drop so there wouldn't be enough flowing to light them all.
Old 06-29-2009 | 02:15 PM
RJ86's Avatar
yes I disconnected the externals and primaries still didnt light up. But before they went out they were working just fine neither lights dimmed or anything. and i was re locating the externals and thats when both primary and externals went out and thats when I disconnected the externals and checked the fuses and bulbs.
Old 06-29-2009 | 03:21 PM
chrisbmo2000's Avatar
sounds like you fried the reverse light part of the switch on the tranny........I dont remember there being and fuseable links back that far.
Old 07-01-2009 | 06:33 PM
Chevy89Silvy's Avatar
When i put external backup lights on mine i used a set of driving lights aim low to the ground. I tapped power from the main light on the drivers side tail light. Since my reverse lights rarely worked when in reverse i traced the wire and sniped it right before in entered into the firewall (pretty sure it was a slime green color) and ran a new wire to a LED toggle switch.. worked great ever since. only issue i had was in the daytime i would sometimes forget to turn em off and come out to a dead battery so i hooked the switch up to a buzzer and now its all good.
dimmuborgir6nik6
10
04-02-2012 08:17 PM
02Z71CP
01-04-2012 01:09 AM
hazzard74
11-11-2011 12:49 PM
Trademark25
10-04-2009 06:07 PM
oldduff
11-03-2005 09:59 PM
Quick Reply: reverse lights
