Running a power wire on 07 SIlverado
Old 03-01-2009 | 07:51 PM
quint2's Avatar
Default Running a power wire on 07 SIlverado
Hi there, Im trying to run a power wire from the engine compartment to the cab to install a HAM radio. The problem i am having is that I cannot seem to find any openings to run thru the firewall to the cab. Does anyone know a good way to get from the engine compartment to the cab, without having to drill any new holes? The battery on this truck is located on the passenger side up by the firewall. Any help would be greatly appreciated. Thanks.
Old 03-02-2009 | 07:52 PM
maxey13's Avatar
Hope you get a reply. I'm interested too..
W9DM
Old 03-02-2009 | 09:06 PM
adamant's Avatar
me to.... i did tap in the on star plug to run my rador detector...
Old 03-04-2009 | 11:28 AM
adampgasser's Avatar
Member
I'm have not worked on any of the nnbs chevy trucks but on other trucks I drill a little hole through the rubber gasket that goes around the steering wheel shaft. I like that spot because the rubber won't wear through the wire like the metal will if a hole is drilled through the firewall. But, I have not worked on the newer trucks so maybe the gasket is not easy to get at.
Old 03-05-2009 | 06:10 AM
adamant's Avatar
thank you,,,,,,,,,,,,,
cubpak89
08-06-2011 05:25 PM
rescue rig the gas pig
03-10-2011 08:43 AM
chevyman18
06-16-2007 04:14 PM
velella
08-20-2006 10:18 PM
gruusome
05-24-2006 01:55 AM
