service engine light on and runs rough
Old 01-06-2014 | 01:06 PM
rjc's Avatar
rjc
Default service engine light on and runs rough
Hello,
New to the site and needing help on my 1994 silverado 2500 4x4 350 with tbi set up.
I replaced the motor last year and only has 2000miles on rebuild.
it was running good up to couple weeks ago, I noticed at idle motor would surge between 500 to 1000 rpm and the service engine soon light comes on. If I drive down the highway truck performs well.
when I shut off and restart, sometimes light will go out and runs idles fine.
What I have replaced with motor, EGR, pcv,new distributor, plugs, wires, new intake gasket and manifold,
Cleaned TBI, Is there maybe a sensor that is acting up, any help greatly appreciated
Old 01-06-2014 | 03:07 PM
Prometheus2508's Avatar
Perhaps issues with the Idle Air Control (IAC) sensor or Throttle Position Sensor (TPS). Check their connections and give them a cleaning maybe, or try them with working models, if you don't want to go on a trial and error purchasing spree.
What you need to do is grab the code that the Engine Light is coming on for. That should provide some clues.
Old 01-06-2014 | 10:27 PM
rjc's Avatar
rjc
Is there a trick to get code? I have a scanner that reads 1996 and newer.
Old 01-07-2014 | 09:54 AM
NullHead's Avatar
This should help: How to read older GM OBD diagnostic codes for free
Will blink the codes for you.
Old 01-07-2014 | 10:29 AM
rjc's Avatar
rjc
Thanks for info, will these codes show up on dash?
Old 01-07-2014 | 10:52 AM
NullHead's Avatar
The check engine light will blink the sequence of the codes, so for example, a code 32 will blink three times, and then two more times to equal a code 32. I believe it will blink the same code like three times in a row, then move onto the next one.
Old 01-07-2014 | 02:45 PM
NullHead is correct. Though the check engine light will first blink once then twice (and repeat this three times) for code 12, meaning the VCM passed a self-diagnostics test. A longer pause will be seen then the trouble codes will flash in the same manner: first number, pause, second number, repeated three times, then loop back to 12.
Old 01-08-2014 | 10:20 AM
rjc's Avatar
rjc
Thanks for replies, I will try that today and let you know results.
tonyh
02-17-2011 11:56 AM
eaa1964
10
09-21-2010 07:10 PM
danza20
03-08-2010 10:30 AM
mikeybrow
04-08-2008 05:32 AM
eaa1964
05-21-2006 04:19 PM
