Service Engine Soon Light
Old 01-23-2009 | 02:14 PM
ahcapone's Avatar
Default Service Engine Soon Light
My SES light came on for the first time ever after taking an off road trip through the desert. I know that you can't check for codes like the CEL. So my question is, how do I know what is causing the light to come on? I did a mild tune-up last February; plugs, wires, air and fuel filter, pcv.
Old 01-23-2009 | 03:07 PM
bfg112's Avatar
Default RE: Service Engine Soon Light
The service engine soon light is the same as a check engine light. If you have an Auto Zone near you they will let you use a scanner for free if they have one. Advance Auto will also let you use theirs, Pep Boys won't, they make you pay the $100 diag charge.
Old 01-26-2009 | 10:39 AM
ahcapone's Avatar
I have a scanner. Now it appears I have 2 problems. I hooked up my scanner and I don't get a reading. My scanner doesn't even turn on. I tried it on another car and it worked fine. Does GM require a special scanner or is there something wrong with my OBD?
Old 01-26-2009 | 10:53 AM
bfg112's Avatar
Not as far as I know. I used the scanner at my local Advance Auto a few times with no special adapters or anything. To the best of my knowledge OBD2 is universal.
Old 02-02-2009 | 12:05 PM
ahcapone's Avatar
So i got my OBD working and pulled a code. P0442, small egr leak. I fount the tube going to the pcv broken in two places and the intake tube disconnected. I replaced the hose and connected the intake. I cleared the code and it hasn't popped up again. Hopefully I didn't get any dirt or moiture to the engine through the intake.
Whitaker24
11-17-2008 05:28 PM
Cvtsax
12
03-29-2008 12:40 AM
RobF1970
08-11-2007 08:27 PM
ffdsmokeeater
10-22-2006 04:10 PM
Quick Reply: Service Engine Soon Light
