should a/c be on with defroster
Old 12-31-2012 | 11:07 AM
gerktj's Avatar
Default should a/c be on with defroster
I have a 2011 Chevy Silverado that fogs up the windows really bad. should the a/c light be on when in defrost mode? Someone told me it should but it's not coming on. I can't seem to get the a/c to stay on at all. It will flash a couple of times then go out. Any ideas?
Old 01-01-2013 | 09:59 AM
Red,'s Avatar
Cool
Should the a/c light be on when in defrost mode?
Any ideas?
Yes ~ have your A/C checked out . . .
Do it yourself if you know how ?
A/C should cycle w/defrost .
The someone was right !
Does the A/C work ?
Red, *<(:{)-
Old 01-01-2013 | 03:35 PM
NullHead's Avatar
Yeah A/C should come on, but only to dehumidify the air inside the truck, like to keep the windows from getting moisture on them after your whole crew has been tobogganing and is all sweaty
The A/C compressor clutch will cycle quickly in this cold weather. It doesn't take much to get low pressures by the evaporator. So if you're hearing the A/C cycle quickly, that is normal. If you are concerned, have someone put some A/C gauges on it and check it out for you.
Old 01-02-2013 | 01:21 PM
gerktj's Avatar
thanks!
Old 01-06-2013 | 04:55 AM
RustyFordLover's Avatar
Yes, it should come on.
jpgoodnu
01-20-2010 05:29 AM
gpet6669
12-09-2008 03:39 PM
DrVortec7081
04-26-2008 03:33 AM
GMCSierraVortecHP2K5
05-26-2006 03:04 AM
Patrick
05-19-2006 04:16 PM
