silverado shakes
#12
silverado shakes
i will check them tomorrow. yes it was shaking before the new motor and tranny . but it does feel like a bent rim or unbalanced tire . i already eliminated that, i changed wheels and tires and it still shook at the same speed 60 to 70
#13
silverado shakes
well i checked my drive shaft and found a bad center u joint . i could feel the play in it so im doing them all and the carrier. they are not that old . the motor and tranny mounts were tight. cant get the carrier off so ill take it to work tomorrow.
#14
silverado shakes
did my u joints and carrier but still shakes. dont know what else to replace
rack and pinion maybe ? this shake is like a splinter , its driving me crazy!! soon i'll have a new truck (with a shake).
#16
silverado shakes
well i camped out under my truck and pretty much went over every bolt,nut ,brace, mount etc. found left rear shock bushing wore out and loose . also got my wife to shimmy the steering wheel back and forth while i watched the rack and pinion and the rack moved back and forth about a 1/4 inch total. i dont know if its supposed to do that? i have a couple of friends at work that have silverados so i'll check theirs out tomorrow.
#18
silverado shakes
i did that also on monday . started out slow to ckeck the tires and rims then took it up to 65 and it ran fine. had my wife do it first so i could see then did it myself for the feel
#19
Visually check the leaf spring bushings. Where they bolt up. Might as well replace them if your gonna take apart to see. But those make a good difference in ride. Bushings are pretty cheap. Bout 20 for a set.
#20
my 99 silverado starts to shake at @ 60 mph. had tires balanced,upper and lower control arm bushings replaced . upper and lower ball joints replaced , shocks ,rotors and it still shakes. i read somewhere to replace the cab bushings. any info or help would be greatly appreciated
I think you should check the wheel alignments of your vehicle. The problem may be there.
