skipping
Old 08-13-2007 | 08:11 PM
chevytillidie24's Avatar
Member
Default skipping
my 95 5.7 is skipping as you take off. at firsti thought it was the plugs. soi changed them and got a little bit better but still skips. i also thought is was the EGR valve. so i changed it also and still skips. so next thing i'm going to adjust the lifters and see if thats it. but if yall know any other ideas let me know asap..
Old 08-13-2007 | 08:38 PM
72charger's Avatar
Default RE: skipping
Skipping as in hesitating, missfiring, bogging down?
Old 08-13-2007 | 08:51 PM
Member
its more of a hesitating skip.
Old 08-13-2007 | 08:53 PM
72charger's Avatar
I'd start with replacing the fuel filter. It could be clogged up if it has never been changed. Especially with it being a 95.
Old 08-13-2007 | 10:33 PM
racethisz71's Avatar
pull the o2 sensor before the the cat and see if it runs better sounds like the cat is starting to clog
Old 08-13-2007 | 11:05 PM
72charger's Avatar
If the cat was clogged it would stay bogged down. I doubt it's that.
Old 08-13-2007 | 11:56 PM
1988BlackMamba's Avatar
have you looked at the cap and rotor also? My g/f truck did that and i changed the cap, rotor, plugs, wires and the air filter and it hasnt done it since.
Old 08-14-2007 | 05:35 AM
Argon's Avatar
plug wire most likely....corroded cap...
white_noyez
10
01-18-2011 11:18 PM
J5diecast
10-26-2009 07:54 PM
chevy291
03-23-2006 01:39 AM
