Slight vibration during initial acceleration - 98 Sily
Old 05-05-2008 | 10:21 AM
ChevySS's Avatar
Default Slight vibration during initial acceleration - 98 Sily
My 98 Sily K1500 4WD 5.7 has 130,000 miles and still runs like new. I am very fastidious about maintenance and repair.
The truck recently developed a noticeable vibration/shudder that only occurs while I gently accelerate from a stop. The vibration/shudder starts at just off-idle speed is only noticeable briefly, then goes away as speed gets above about 10mph.
If I had to guess, I'd say it feels like it is coming from tranny area.
Any suggestions? I'm guessing driveshaft yoke or u-joint??
thanks for all suggestions.
Old 05-05-2008 | 10:51 AM
jcbst12's Avatar
Default RE: Slight vibration during initial acceleration - 98 Sily
My money is on a U-joint. Check the rearward most U-joint right before the rear diff.
Old 05-05-2008 | 01:08 PM
6mins2live's Avatar
U-JOINT.
Old 05-06-2008 | 06:26 AM
ChevySS's Avatar
Thanks, I am gonna remove the driveshaft today and check...................
Old 05-06-2008 | 10:31 AM
ChevySS's Avatar
Many thanks for the replies. I pulled my rear driveshaft. The rear u-joint is less than a year old and was fine. The front u-joint has a teeny amount of wear. One end of the joint had some small wear ridges, so I replaced it. The yoke looks new, but I greased the splines prior to re-assembly.
Re-installed the driveshaft, but problem not fixed. I still get the vibration between 1,000 and 1,500 rpm, then it goes away. I feel the vibration mostly in the gas pedal with my right foot. It's extremely annoying for stop-and-go driving, which is mostly what I am doing.
If anyone has any suggestions, please post.
Thanks.
Old 05-06-2008 | 10:34 AM
04BLKCHEVY's Avatar
Check your motor mounts or tranny mounts. Most likely your motor mounts.
Old 05-06-2008 | 05:46 PM
03missouridirt's Avatar
torque convertor?
Old 05-07-2008 | 09:50 AM
gpet6669's Avatar
First, one more question. Does it do it when in park and you rev the motor, also can it stay doing it when you stay at the low speed? Or does it just go away right after it starts? If it doesn't do it when you are in park or in neutral and it goes away right after it starts, then I would have to say either the torque converter it locking and unlocking or, the tranny is trying to shift but not quiet in one or another gear. Kinda shifting back and forth between the gears. It is kinda common when the tranny has electronic controls with a mechanical kick down cable. Those are my thought on the issue. Good luck.
Old 05-07-2008 | 01:26 PM
ChevySS's Avatar
Well, I found my vibration and wanted to post here. I mostly felt the vibration through the gas pedal.
I replaced one u-joint (the other was new), but that did not fix it.
So I concentrated my focus in the gas pedal area and found the throttle cable laying firmly against the oil filler neck. I used a zip tie to hold the throttle cable away from the filler neck and PRESTO, the vibration is gone.
Thanks for help and suggestions
IronBear
24
07-06-2018 01:52 PM
lorennmeg
09-04-2011 12:04 PM
BrokedownRunner
06-27-2010 09:19 AM
esparpete
02-18-2008 06:29 PM
eaa1964
05-21-2006 03:19 PM
Quick Reply: Slight vibration during initial acceleration - 98 Sily
