Sporadic starting problems
Old 01-04-2007 | 09:12 PM
dtomlin's Avatar
Default Sporadic starting problems
OK, I'm thinking it might be the starter interrupt but not sure. Or, the truck '01 Silverado has PMS, about once a month, it won't start. First time it happened, I took the car to work and forgot to check it that night and the next morning - it started. Next time it happened, I replaced the battery (the next day) and it started. It's happened about three times since then, and today is one of those days. No power is getting to the starter. Is there a starter interrupt module? Dealer can never get it in same day - the next day it starts and they can't reproduce it.
Any advice, opinions, thoughts, guesses would be appreciated.
Old 01-04-2007 | 09:27 PM
smoke20's Avatar
Default RE: Sporadic starting problems
Sounds like a starter relay. Does you hear any noise from under the hood, like maybe a relay clicking, or even your fuel pump priming? Could also be an engine ground issue. I had one burn up on my old truck and would have same issue depending on how well ground was touching frame.
Old 01-05-2007 | 03:44 AM
under construction's Avatar
i agree with smoke, that ground can really mess with you...check and make sure all the ground wires are on tight...make sure there is no acid on your battery either...
Old 01-07-2007 | 02:52 AM
sc64chevy's Avatar
The battery terminals were causing the same problem on my truck a sporadic no start. I replaced them and it fixed the problem,
GMCSierraFan
12-14-2010 12:49 AM
87V6Dakota
10-04-2007 10:17 AM
cookytruck
08-06-2007 08:14 PM
siar6100
06-12-2007 08:30 PM
Ballzac
01-08-2007 12:38 AM
