squeek,squeek,squeek
Old 07-09-2009 | 02:04 PM
89silverado's Avatar
Default squeek,squeek,squeek
I have a 1989 Silverado 2wd. When I start from a stop I hear squeek,squeek,squeek. Sound like it's coming from the rear end, I'm thinking u-jouints maybe? Are they hard to replace?
Old 07-09-2009 | 03:06 PM
I would check the brakes first. Does it only do it while moving? Some U-Joints have grease fittings - I would grease them before replacing.
Old 07-09-2009 | 08:15 PM
RUFFNECK4LYFE's Avatar
Yeah could be a few things. Rear brakes, u joints, leaf spring bushings, etc.
Old 07-09-2009 | 08:48 PM
1993GMCSierra's Avatar
My old GMC did the same thing. It was the carrier bearing.
Old 07-09-2009 | 08:49 PM
bigblue81's Avatar
Member
easy way to check you joints crawl under truck grab driveshaft at rearend and start shaking if it has any play start thinking about changing it just changed mine for same reason but if it dont have any play grease them like Mr Shamrock mentioned
Buster_89_79
05-05-2008 08:32 AM
Chevycowboy
04-05-2008 11:00 PM
98tanchev
8
06-24-2007 06:22 PM
jonsgmc
01-19-2007 03:27 PM
midge93
01-15-2007 03:08 AM
Quick Reply: squeek,squeek,squeek
