Stereo and Sub
RE: Stereo and Sub
I had the same problem man.
If you do some research though, you can buy a converter that will work on your factory head unit. Ask any stereo shop and they should be able to hook you up.
Also, this may be just a rumor, but I heard that some of the newer GM radios were coming from the factory with RCA pre-outs.....
Good luck.
Good luck.
RE: Stereo and Sub
hey guys the piece your talking about is called a LOC-2 converter, it just basically taps into your speakers in the door for signal instead of using RCA cables. it is th same setup pretty much. i had it in my saturn and it worked great, never had any probles with it.
drw33079`
01-26-2009 10:11 PM
fixitaz
05-22-2007 02:26 AM
tech12volt
09-07-2006 01:05 AM
