Strange overheating issue... 1984 GMC 3500
Old 08-31-2010 | 08:31 PM
redjeepgirl's Avatar
Default Strange overheating issue... 1984 GMC 3500
Hi, guys
I have a 84 GMC 3500, manual. I swapped the engine with a older guessing 70s engine, 350, nothing special about it as far as I can tell. Everything works great, except when traveling on the highway. It gets pretty close to the red line when I'm going 65-70 mph, but if I slow down to 55, or even in stop and go traffic, the temperature stays around 230 degrees, a bit to the right of the middle range of the gauge. I never get any coolant or other weird smells indicating something is going on. I occasionally get belt slipping, but I can't figure out what is causing it, everything works great most of the time.
Before I start yanking water pumps, thermostats and radiators, I was hoping that someone could give me some wisdom. This is the first vehicle I've owned that gets hotter when driving at steady speeds, but cools down in stop and go. Thanks!
Old 09-01-2010 | 07:30 PM
mrfisher86's Avatar
i had a friend that this happened to, and it was a thermostat, it should be cheap fix, good luck
Old 09-01-2010 | 08:38 PM
chrisbmo2000's Avatar
Sounds like you have a bad thermostat. as stated in the other post by mrfisher86 its a cheap fix
SplashBurn80
03-26-2013 01:12 PM
glodan38
03-22-2012 11:59 PM
Brian74
02-26-2012 09:53 PM
chrisbmo2000
01-27-2009 11:14 PM
Chuck
12-16-2008 07:37 PM
Quick Reply: Strange overheating issue... 1984 GMC 3500
