Temperature Gauge stuck at 160 degrees.
Old 05-04-2013 | 10:18 PM
Mazzella's Avatar
Default Temperature Gauge stuck at 160 degrees.
My 2004 Chevy Silverado 2500HD has temperature gauge stuck at 160 degrees. I have replaced thermostat, flushed the coolant so far. Truck does not appear to be driving any differently but gauge is stuck. I am looking for other areas to troubleshoot, any thoughts?
Old 05-05-2013 | 03:36 PM
TMW's Avatar
TMW
Most likely the gauge is bad and it's part of the instrument cluster. GM instrument clusters are a problem for many years. My 04 GMC has been replaced twiced.
Old 05-14-2013 | 12:30 AM
Mukilteo's Avatar
Default It's a Voltmeter
If you can get the cover off, see if it will move. Then turn on the key and see if it moves on its own...if it doesn't, consider it an excuse to replace gauges.
Except...have you checked the voltage at the temp sender? Your gauge is really just a voltmeter with a differently painted face and the sender a variable resistor. Make sure you have juice flowing down the wire before you do anything else.
Old 10-28-2021 | 11:15 AM
Hotrod420's Avatar
Default Temp gauge stuck
I filled my water and the temp went to 160 and the fan runs more. Is it safe to drive?
ghostpopi
03-22-2011 08:08 AM
bodenejeff
01-03-2011 09:42 PM
batmanwb
09-05-2008 01:02 PM
94 chevy1500
03-17-2008 12:28 AM
tripuhlet
10-03-2005 10:13 PM
