Is there an easy way to clear a check engine light
Old 09-24-2014 | 02:30 PM
pontiac69's Avatar
Default Is there an easy way to clear a check engine light
I have an 05 Silverado and i did a throttle body cleanning. After i was done the check engine light came on. I want to clear it. Is there a way to clear it without going to a mechanic. I already disconnected both positive and negative terminals for about 30 min. Light is still on. I know nothing is wrong it was because of the cleaner i was shooting into the throttle body. I used Seafoam cleaner.
http://www.softys.ca/image_items/seafoam/ss14.jpg
Old 09-24-2014 | 06:51 PM
poncho62's Avatar
You can buy a scanner for under $100 which will erase the codes.....Probably a little more than a mechanic would charge, but they are real handy to have for future problems, which are bound to come up sooner or later
and, it would be useful to find out what code did come up
Old 10-01-2014 | 02:41 PM
TMW's Avatar
TMW
Getting the code is a good ideal to see if it's related to what you did. Otherwise you can disconnect the battery to clear the code. Some vehicles like Range Rover say to disconnect the battery and connect the pos. and neg. cables together for a minute or so.
Old 10-01-2014 | 08:27 PM
poncho62's Avatar
The pre 96 OBD1 system, you could erase the codes by disconnecting the battery. After 96 OBD2, it retains the codes in memory......you need a device to erase codes....ie:scanner, computer program
Old 10-09-2014 | 11:37 AM
TMW's Avatar
TMW
My Chilton 1999-2006 chevy/GMC manual says you can disconnect the pos side of the battery or pull the PCM fuse. My Haynes manual for my 2004 Toyota says the same thing and details it for the OBD1 and the OBD2 systems. Personally I have only had a light on my 2004 GMC and I replaced the sensor to fix it.
Old 10-10-2014 | 10:22 PM
NullHead's Avatar
I've found that normally, disconnecting the battery will erase any codes stored in the computer, current or history. What changes the fact that the light stays on, is most likely because there is a current issue going on, and the computer encounters a problem right away and sets a fault code again. I'd say it needs to be diagnosed, at least have your idle reset after you cleaned the throttlebody.
Worf
GM How-To's and Tutorials
12-05-2012 04:34 AM
Worf
Dodge/ Ram How-To's and Tutorials
12-04-2012 04:59 AM
Worf
11-29-2012 09:10 AM
Worf
Ford How-To's and Tutorials
04-08-2010 05:14 PM
Worf
04-08-2010 05:02 PM
