Thermostat swap questions
#16
RE: Thermostat swap questions
I have a 160 in mine and noticed like 5 miles less to the tank... Made more power, too... I'd say get the 160 and toss it in there... You will love the results... And it WILL kill your grass!!!
#18
Most vehicle thermostats are a made by expanding metal opening a valve to let colder radiator water into the engine. So, a 180 degree thermostat essentially just opens and closes a little at a time to balance the internal engine temp to 180 degrees. I don't know about newer vehicles or not but the only way you could have a selectable thermostat would be to put a thermometer, computer (or mechanical switch), and a actuating valve.
Much simpler are metal expansion valves
#20
It's like a 2" hose, isn't it? You'd need like a steam valve to do the switching. Still, on the older engines, it's two bolts. For the cost of about an hour of work and two little gaskets every six months, it wouldn't be hard to do it manually. (Not sure about new engines)
