throttle body
Old 07-16-2007 | 08:28 PM
99 z71 man's Avatar
Default throttle body
i just bought a 99 z71 with the 5.3. i was thinking about getting a bigger throttle body. i was wonderin if i get a throttle body spacer will it work with a bigger throttle body? im assuming that the spacers whole opening is the same size as the stock? any input would help.
Old 07-17-2007 | 06:54 PM
smoke20's Avatar
Default RE: throttle body
Not sure about your question, but from what I hear the aftermarket throttle bodies are not worth it. very little power increase for alot of money. may be better to port the one you got.
Old 07-17-2007 | 07:13 PM
99 z71 man's Avatar
really? so what is the diff between porting the stock one and buying one that is like 80 or 85 mm? wouldnt porting the stock one doing the same thing?
Old 07-17-2007 | 09:16 PM
smoke20's Avatar
It seems like it should, but all the feedback I have seen is negative. So it seems that saving your money and porting your own would be a better deal. I am no expert on these, I have just read a little on them.
Old 07-17-2007 | 09:20 PM
99 z71 man's Avatar
thanks for the advice. so do throttle body spacers help then? and how do you go about porting your own? a tool and die shop doing it? or is there a cheaper way to do it myself? thanks again for the advice!!
Old 07-19-2007 | 12:36 AM
big red's Avatar
I could be wrong but I thought that the 4wd's came with the 85mm throttle bodies . But usually bigger is better when it comes to throttle bodies. But if you go to big with a cable actuated throttle body it can make low RPM driving challenging
Old 07-19-2007 | 10:10 PM
smoke20's Avatar
MrLM7 had a recent write up on this. If you look at the old posts you will see a write up on how to do it. I have not done it, but it appears to help some. I think you will be happier with a reprogram though.
Old 07-21-2007 | 02:04 PM
popo's Avatar
I just did mine and it made a world of difference. Just look through the old posts and you will see mine and the one Mrlm7 has as well. it was VERY easy.
bigred29067
05-24-2008 04:14 PM
smoke20
03-30-2007 07:31 AM
Ballzac
8
02-15-2007 10:33 PM
blocker
02-09-2007 11:13 AM
gandolfor
12
01-26-2007 04:48 PM
