Timing
Old 02-06-2007 | 09:43 PM
novaman7088's Avatar
Default Timing
I am putting in a new 350 motor in my 93 and had someone tell me to time it I set the timing at 0 unplug a wire from the distributor but he was not sure witch one. If I could get some help that would be great.
Old 02-11-2007 | 06:56 PM
little wolf's Avatar
Default RE: Timing
It is usually a tan color wire with a connector near the relay panel just above the heater box under the hood.
Old 02-11-2007 | 07:11 PM
vetteboy86's Avatar
Default RE: Timing
On other chevy's this is the EST (electronic spark timing) wire. I think this usually retards the timing 6 degrees or so. Is the motor running now? If it is you should be able to get close with or without this wire unplugged.
errodri1961
10-09-2007 08:11 PM
webbch
02-08-2007 01:54 PM
nluoma
02-17-2006 08:22 PM
specht
11-25-2004 02:16 AM
