Tire size question?
Old 10-14-2007 | 10:55 PM
jaybob314's Avatar
Default Tire size question?
what is the largest tire you can fit on a 1999 silverado with stock suspension
Old 10-14-2007 | 10:58 PM
BlackHorse99's Avatar
Default RE: Tire size question?
im runnin 285 75 16s now, i have run 305 70's before with torsion jacking
Old 10-14-2007 | 11:01 PM
jaybob314's Avatar
is torsion jacking what makes the front end sit level with the back. and if so how does it work
Old 10-14-2007 | 11:22 PM
yeah, it just turns your tosrion bars to the max, making your front end always be maxed to its highest ride. makes for a stiff ride and isnt good for alignment
Old 10-15-2007 | 06:52 PM
jaybob314's Avatar
Would purchasing torsion keys for my truck achieve the the same ride heigth in the front as in the back? thanks
Old 10-15-2007 | 07:30 PM
Cracker's Avatar
Yes, torsion keys are what you need. You'll spend between $60 and $100 plus an alignment and possibly sacrifice your ride quality. Maxx Cam is pretty good and adjustable.
If you want to fit bigger tires, install a body lift and you can fit 35's. On stock rims you'll rub in hard turns or turning during suspension flex, but not much.
Old 10-15-2007 | 10:59 PM
jaybob314's Avatar
would i sacrifice anything by running 285 75-16's
Old 10-16-2007 | 12:36 PM
seb37's Avatar
This is my second set of 285/75-16 in three years and have not had a single problem, even though Mickey Thompson recommnends at least a 2in body lift
majordad
20
03-02-2023 03:17 PM
onegroovydude
07-18-2009 10:00 PM
2500_DW
10
11-27-2008 02:12 PM
chevy112488
04-27-2007 12:51 AM
bjs2000
03-06-2006 10:52 PM
Quick Reply: Tire size question?
