Tow Haul mode
Old 04-20-2010 | 07:17 PM
Jim Rodman's Avatar
Exclamation Tow Haul mode
Hi every one
I am asking for help on two issues.
1: My TOW HAUL MODE quit working last summer. At first it would work and then not work.
Now it will not work at all.
2: The curse control is not working at the same time.
On both I have not yet found the fuses, do to the fact that I lost my Operators Manual. That was a dump thing for me to do.
Any help to fix this would be appreciated.
jim from Ontario
Old 04-20-2010 | 07:44 PM
HarderThanRocks's Avatar
If you cant find the fuses "do" to the fact that you lost your operators manual, you have more serious issues than not having your tow/haul mode and your "curse" control...
Old 04-20-2010 | 07:47 PM
Ok, now that that is out of the way... There is a fuse box under your hood on the drivers side, and a fuse panel on the drivers side of the dashboard, all the fuses are labeled... good luck and check for disconnected wires...
Old 04-20-2010 | 07:59 PM
chevy112488's Avatar
if it worked intermittently for a while before it quit, its not very likely to be a fuse. i'd say the switch in the shifter is probably bad
Old 04-25-2010 | 07:55 PM
chevyrules's Avatar
Default Tow/Haul Mode
My 2003 Silverado has the same problem. I was told to check the wires in back of the rubber boot on the shifter lever. Theres a Green wire, that has a tendancy to break over time. I haven't had time to check mine out yet but will eventually. Good luck, let me know if thats the problem as mine was working intermittently as well, then i'd manually shift the tranny down 1 gear, then push the tow/haul mode button and it would work, then it stopped working all together, now when needed, i shift it down 1 gear and off i go. Good luck, like i said, please let me know what you find, Jim
VAC
11
07-13-2010 01:29 PM
Pelicandivebomb
09-03-2009 07:18 PM
chevyrules
04-14-2009 12:31 PM
bad2006z71
03-06-2008 12:00 AM
Z71TwoTone
12-22-2006 07:42 PM
