transmission cold shifting problem below freezing
Old 12-08-2007 | 06:52 PM
mgd219's Avatar
Default transmission cold shifting problem below freezing
transmission won't shift into 3rd or o.d. 1-2 shift is hard.need to shift into 3rd manually at 35 mph. only have this problem when its cold out. if driven for about 5 miles and park for a few minutes it works fine.shifts fine when temp is over 35 deg. trans is the 4l60e
Old 12-08-2007 | 06:58 PM
JakeSilverado's Avatar
Default RE: transmission cold shifting problem below freezing
change your fluid and filter. Mine did some wierd things while it was cold, changed the filter and fluid and now it's perfect.
Old 12-08-2007 | 07:52 PM
seb37's Avatar
How many miles on Truck?
Old 12-08-2007 | 08:50 PM
mgd219's Avatar
84,000 miles just bought it used trans fluid looks new
Old 12-08-2007 | 10:34 PM
seb37's Avatar
I would probaly still do a Filter and oil change and see what that helps at all
Old 12-09-2007 | 10:59 AM
Changing the filter is really easy. When you do it try and save the factory gasket if you can. Those cork gaskets are junk.
Old 12-10-2007 | 07:08 AM
Argon's Avatar
something is hanging up in nthe valve body...i'd probably change or get the solenoids changed while its opened up
In2Trux
01-25-2012 04:23 PM
jdm_gadget
Vehicles for Sale
04-07-2011 08:32 AM
T_R_G
09-21-2010 10:42 PM
Firefighter1669
02-23-2010 02:54 PM
big-silver
05-20-2009 12:18 PM
