Transmission problems -- ECM the cause??
Old 07-28-2007 | 01:05 AM
91k1500's Avatar
Default RE: Transmission problems -- ECM the cause??
sun shells full name would be sun gear reaction shell
  #12
Old 08-06-2007 | 06:55 PM
jackrabbithanna's Avatar
I"m sorry for the time lapse in responding....the fuel pump went out now and I've ordered a new one.....My transmission is a 700r4....
Nobody thinks that the probably could be in the ECM?????
  #13
Old 08-06-2007 | 07:10 PM
The ECM is unplugged because the motor is carborated and not fuel injected anymore. How can I bypass the computer and have the transmission's torque convertor unlock when necessary?
The transmission is a 700r4......maybe I should post a new thread...how to make the silverado run without a computer.
  #14
Old 08-06-2007 | 07:16 PM
Argon's Avatar
the trans is not controlled by the ecm..just the lock up is...she shifts off vacuum and pressure ..and good ol mechanical valves n linkages
  #15
Old 08-06-2007 | 07:17 PM
91k1500's Avatar
i did a lil lookin on alldata to be sure, and i found there are some electronic controls for the 4-3 shift that i was unfamiliar with on these trucks. if your only symptom was no OD i wouldnt rule out the ECM, but having no reverse, the ECM has nothing to do with that. the only way i can see this being ECM related problem is if gnomes placed an ECM inside of your transmission.
  #16
Old 08-06-2007 | 07:28 PM
Argon's Avatar
does it lock up?
  #17
Old 08-06-2007 | 08:03 PM
jcbst12's Avatar
Our work truck, a 89' silverado, had similar symptoms and when we took it into the shop. It didn't hit third, didn't want to downshift and no reverse. It was a few years ago but all I can remember is that the cheapest alternative was a reman tranny.
  #18
Old 08-07-2007 | 08:41 AM
yeah....I'd like to bypass the computer controllled lockup if it is possible......not necessarily the easiest thing to do.....Is there a way to rig a switch which unlocks the torque convertor and bypasses the computer??? I have a standard transmission I could put in but making a standard fit where a automatic should be isn't easy either....
paul6677
09-09-2012 07:37 PM
chevy.man
10
07-16-2010 01:26 PM
K3500dump
11-10-2009 05:18 AM
chevyrules
8
08-01-2007 06:40 PM
Quick Reply: Transmission problems -- ECM the cause??
