truck grinds when i try to put it into 4 low
Old 09-23-2010 | 11:10 PM
kessel_5's Avatar
Default truck grinds when i try to put it into 4 low
i have a 1998 chevy silverado, with push button 4 wheel drive and my truck will go into 4 hi fine without any problems but when i try to put it in 4 low it wont go in and it just grinds terrible. i have to put it back in 4 high so it will stop grinding. when i try to put it into 4 low i d o have it in neutral. any ideas what is wrong with my truck. thanks
Old 09-24-2010 | 06:06 AM
Ideally, you should be in neutral with the Parking brake set. I have the floor shifter on the same model truck and it has to be in neutral or it won't move. When it does move, I have to keep it at a steady slow pace while moving it otherwise it will grind
Old 09-24-2010 | 08:17 AM
kessel_5's Avatar
if i have my truck in neutral and then put it in 4 low it goes in, but when i put it in gear, it starts grinding terrible.
Old 09-24-2010 | 10:15 AM
chrisbmo2000's Avatar
Chevrolet was always weird about their 4x4. You need to put it in neutral in order to put it in 4x4, its the way the t case is built
msanpietro
01-13-2011 09:17 PM
kessel_5
09-23-2010 11:07 PM
jcbst12
15
02-11-2008 10:27 AM
makoltd
12-04-2006 02:35 AM
hybrid_malibu
08-16-2005 03:05 AM
