Truck overheats going up hill only
Hello everyone. I have a 95' GMC Sierra, 5.0 extended cab, 2wd. I am having a problem with it overheating, only when I go up any hill. I can run it wide open 85-95mph no problems, loaded or unloaded. Anytime I go up hill empty or loaded the temp flies up, if i dont run the heater it will most likely overheat. I have rebuilt the Radiator and replaced the heater core, (it leaked into the cab) the thermostat is not the problem according to the mechanic I saw. Please help. If I replace the fan clutch would that do anything? Thanks for any input.
cubpak89
07-11-2011 07:21 PM
SouthBayZ71
22
08-22-2007 10:38 PM
