Truck skipping/not getting gas?
Old 10-26-2009 | 03:24 PM
J5diecast's Avatar
Default Truck skipping/not getting gas?
I have a 1990 Chevy Silverado that recently started backfiring every once in a while and seemed to be struggling for gas at the same time-sounded like it was skipping (usually when going uphill). Only did it every once in a while. Changed the fuel filter and it stopped. It has started back only worse. Changed the fuel filter and it did not help this time. Now it won't stay cranked. You can crank it up, but you have to keep stomping on the gas (it doesn't rev up) and when you let go of the gas it dies. Any ideas of what this might be????? I could use all the advice you might have.
Old 10-26-2009 | 06:24 PM
SlimJim's Avatar
Check fuel pressure. It may be a bad fuel pump.
Old 10-26-2009 | 07:54 PM
RUFFNECK4LYFE's Avatar
Yeah rule out fuel problems before you start replacing parts.
white_noyez
10
01-18-2011 11:18 PM
colbycrockett
01-02-2010 11:56 PM
preciserem
05-16-2009 06:58 PM
chevytillidie24
08-14-2007 05:35 AM
chevy291
03-23-2006 01:39 AM
