Truck wont start
Truck wont start
Hey guys i need some help! So I went out to go to class this morning and i tries to start my truck and it would not start... Everything else is working properly... the fuel pump is ingaging and all my electronics are working and the battery has a full charge.... when you turn the switch all that happens is the starter will click but then nothing.... i tried jumping it off and everything..... it is cold outside so i figured that might have something to do with it but i dont know..... please help!
RE: Truck wont start
When it was really cold outside my last truck would do that, try and atach a jumper pack to the battary and start it up, used to work for me, cuase its a little more juice than a regular jump. It could also be your starter, try and put the jumper cables right to the starter and see if it turns over. It could be seized up. Hopefully thats not the case though. Good Luck!
my truck just had the same problem. if you look back i posted a thread bout this too. i even replaced the battery cuz i knew it was going bad.when i gotthe new battery, it still wouldnt work for me.more than likely your starter. i bought a new one and am changing it out tomorrow
I forget exactly if you have the battery posts or side screws on that truck. I had the side screws on mine with that issue. I went to an optima deep cycle when it got colder and that crap started figuring that the battery acid mighta been gellin or somethin.. Didnt change so I went and installed the standard terminals for the posts (as the optima had both), got a tight fit and hadnt had a problem since. Not sayin itll work for you but terminals cost 5 bucks vs a 150 dollar starter.Get the thick ones tho, none of those crappy nissan band terminals. Always want a good solid electrical system...
underoathpac
08-10-2007 04:53 PM
