Tune-up and other questions
Old 06-06-2010 | 12:57 AM
fr8train's Avatar
Default Tune-up and other questions
Hey all, this is my first 'real' post. I am going to do a tune-up to my truck tomorrow. I plan on addressing the following:
  • Plugs and wires
  • PCV
  • Fuel Filter
  • Clean TB and MAF
Anything else I should check out? Also what do you recommend to use to clean the TB and MAF?
And my other question is, the other day my airbag light came on, took it to the shop to get the code pulled, no code for the airbag, however there was a code for the EVAP. I had no CEL, and then we noticed that the CEL is not working, not even on start up. Can I fix this or is it a problem in the cluster? Also can the EVAP be cleaned or does it need replaced?
Thanks for any tips.
Mike
Old 06-06-2010 | 10:07 PM
fr8train's Avatar
got the tune-up done today, replaced plugs n wires, Cleaned the MAF and TB. She's running great. I have a few other things that I need to address though.
My airbag light is on and message center says Check air bag but has no code.
also my CEL is not working but the code in the PCM says EVAP Purge valve, so I need to address that.
Also, I tried to get a fuel filter and a PCV valve, but they aren't available for my truck. Stores computer says my truck doesn't have a PCV and the fuel filter is 'not serviceable' guy said it is in the fuel tank.
Any ideas on the PCV and fuel filter?
Thanks
Mike
Old 06-06-2010 | 11:57 PM
chrisbmo2000's Avatar
you have no pcv and yes the filter is in the tank....are you sure the evap is not a stored code?????.......stored codes sometimes will not kick a cel
Old 06-07-2010 | 12:30 AM
fr8train's Avatar
I am not sure if it is a stored code or not, but my CEL doesn't come on at startup, so I'm pretty sure the bulb is out.
Old 06-07-2010 | 09:10 AM
RUFFNECK4LYFE's Avatar
The PURGE VALVE is located on top of the intake manifold in front near the throttle body. It costs about 45 bucks. Do you notice a gassy smell while its running?
Old 06-07-2010 | 06:26 PM
fr8train's Avatar
Ruff, I found the purge valve w/o a prob over the weekend, and no I don't notice a gassy smell while driving.
Old 06-07-2010 | 08:58 PM
Well have the codes cleared and see if it pops up again. Mine was saying the same thing one time, and it turned out to be a popped fuse under the hood.
nyg052003
03-08-2012 11:59 AM
iward05
8
09-18-2011 02:55 PM
Keizer
09-18-2008 10:00 AM
MrLM7
06-30-2007 11:29 PM
smoke20
03-01-2007 11:01 PM
