tuning
RE: tuning
I had tbichips.com do mine before I modded my 91' and I was impressed with the difference. I had to run 91+ (with the stage 1 chip) but the little 5.0 would actually pull hills and merge into traffic without redlining it. Then I added a TBS, vortec heads, duals, MSD ingnition system, 160 stat, intake and bigger injectors, etc... on my truck. I had him reprogram my chip (to a stage 2 for a nominal fee) and you would have thought I had a modded 350 under the hood with how well it ran. Do the Jet chip if you want, but this guy can "dial it in" for you based on your mods and the chip is easy to swap.
RE: tuning
I figured it too at first, but the guy has been around for the last five years and I've delt with him alot and recommended him to my friends. He just takes some of the guess work and alot of frustration out of modding the TBI motors.
RE: tuning
I have a set of vortec heads from a 350 suburban gathering dust and rust in my garage. They are iron so shipping may be expensive, but, you are welcome to them. I no longer need them. They will need to be cleaned. The valves and springs are present. The springs will need to be replaced.
