what diff ACDelco 746MM and 9746MM Spark plug wire sets
what is the diff between ACDelco 746MM and 9746MM Spark plug wire sets
i'm looking to replace my original spark plug
and coil wires for my 1999 4.3L 160k mile truck.
not sure what band/ kit to get. I usually stick
with ACDelco for stuff like this
seems ACDelco has two kits:
9746MM is associated with 88862415
746MM is associated with 88984266
i think those are GM part numbers
any one know the diff?
maybe one comes with the coil wire, the other doesn't?
maybe the conductor?
insulation?
temp range?
insulation?
temp range?
local NAPA says they don't carry ACDelco sparkplug wires and doesn't know who does carry them.
the ACDelco site has both 97466mm and 746mm in their catalog, which says both are applicable for my engine, but parts pages do not provide a description.
That's absolutely absurd. I just bought a set of genuine Delco plugs for my truck. Here are the spark plugs that work with your truck at MY local NAPA store. The part numbers will be slightly different than when the truck was new, but I would print that out and show it to the NAPA guys... sounds like a new guy to me
http://www.napaonline.com/Search/Res...60&Ntk=Keyword
The part numbers are for the wires as opposed to the plugs
chevychase - yep, not sure, the 9746mm and 746mm are ACDelco part numbers, not dimensions.
joedirt830 - just a standard 4.3L engine
GMCSierraFan - thats what I said. the response was "no acdelco ignition wires"
I called R A, since they sell both kits. Response was nothing more than a bit a talk about this and that mfr ... no technical specifications.
I also did some more researching ... still news on the difference.
... i thought i'd bump this thread one last time to see if anyone has information on the difference between two ignition wire kits that are spec'd for my 1999 4.3L engine.
AC Delco has 9746MM and 746MM as part numbers for the wire kits. i've not been able to find out the difference after a few phone calls and a fair amount of online searching.
... or any recommendations on a different brand/part ?
silv99
09-19-2020 06:43 PM
cubpak89
08-06-2011 04:25 PM
LBTruckin
03-19-2011 03:03 PM
trevort
09-25-2007 05:52 PM
