What is a locking rear diff?
Old 02-05-2007 | 11:46 AM
vetteboy86's Avatar
Default What is a locking rear diff?
I see that there is an option for a locking rear diff? How is this different from other diffs?
Old 02-05-2007 | 10:10 PM
smoke20's Avatar
Default RE: What is a locking rear diff?
A locking rear diff locks both sides of the axle together so both rear wheels constantly turn evenly, as opposed to other diffs that transfer most (or all) power the wheel with the least traction. What happens without a locking rear diff is if you have one wheel off the ground, then it will get all the power sent to it, while the tire on the ground that actually has traction gets no power. With a locking diff even if one tire is in the air the other will still get 50 percent of the power sent to it. The reason non-locking diffs are used is so as you go around a corner, the wheels can turn at different speeds (since outer wheel has to go father than inner wheel when making a turn. This is just a basic explanation, as these systems are much more complicated, and there are many variations of non-locking diffs.
Old 02-05-2007 | 11:56 PM
Chevyvehc's Avatar
http://auto.howstuffworks.com/four-wheel-drive.htm
Start Reading =) Hopes this helps
Old 02-06-2007 | 09:54 PM
chevy1224's Avatar
Thats a good site... anyway, I think its alot like posi-track if not the same thing.
Old 02-11-2007 | 05:25 AM
SC_Chevy_Lover's Avatar
Yep, it is very similar to positive traction.
OntheRoadAgain
17
12-12-2011 11:49 AM
Rich
12-01-2009 11:37 PM
Z71TwoTone
18
12-07-2007 09:09 AM
Bbellsilverado
08-06-2007 07:07 PM
Rbizz
07-11-2007 03:00 PM
Quick Reply: What is a locking rear diff?
