What is a normal transmission temp?
Old 04-02-2009 | 05:10 PM
Pelicandivebomb's Avatar
Default What is a normal transmission temp?
My Silverado has a trans temp gauge and I usually see it run anywhere from 120-170 degrees F. The highest I saw it get was 195 and I was driving slow up a curvy hill on a day where the outside temp was about 100 degrees. I just wanted to know what everyone else sees on there gauges (if you have one, I know it isn't common) and at what temp would I need to be concerned about?
Old 04-03-2009 | 02:07 PM
DamnYankee's Avatar
That's normal.
Without question though, you should put on a cooler and deeper transmission pan. The heat is what usually kills transmissions...you can greatly extend the normal life of one by keeping temps lower.
Old 04-03-2009 | 07:23 PM
Default Thanks
Thats good news to me knowing that is a normal temp. I have a transmission cooler which I believe was part of the tow package. I could put a deeper pan on but I'm not sure how much cooler it would run and if the price of it would be worth it in the long run. I do good maintenance and check fluid levels almost everyday. How much more fluid is usually needed with the installation of a deeper pan?
Old 04-03-2009 | 11:00 PM
DamnYankee's Avatar
The deeper pans typically take 2 more quarts and lower temps around 40 degrees. That's big and honestly shouldn't even be a question whether or not to do it.
A stock cooler is good, but you would do well to add an aftermarket cooler. Weigh the cost of a new cooler against the cost of rebuilding a trans because the clutches burnt up due to higher heat. It's a no-brainer.
Old 04-05-2009 | 12:41 AM
I will probably get a bigger aftermarket cooler and a deeper pan when I go to replace the fluid. I have less than 30,000 miles on the truck right now and plan to do that at the 50,000 mark. The owners manual says 100,000 but I do fluid changes much earlier. I don't even let my engine oil reach 3,000 miles. I know it may seem extreme to some but thats just how I am.
Old 04-05-2009 | 09:20 AM
DamnYankee's Avatar
pearjn
08-29-2012 01:27 AM
986crazy
06-14-2010 03:55 PM
cyberfriend
02-15-2009 01:32 AM
felix arrizon
11
04-27-2007 06:47 PM
gas guzzlin 4x4
04-03-2007 11:40 PM
Quick Reply: What is a normal transmission temp?
