what part is this for?
Old 02-09-2010 | 08:28 PM
zach24's Avatar
Default what part is this for?
hey guys my sierra 93 c1500 had a part in it that looked like this....
where does it go and what does it do thanks
http://i220.photobucket.com/albums/d.../Truckpart.jpg
Old 02-09-2010 | 09:29 PM
bharmon444's Avatar
From what i can see in the picture its an after market radio antenna converter, but i could be wrong It plugs into the factory antenna and then it plugs into the after market radio .
Old 02-10-2010 | 07:47 AM
Yeah that's a radio antenna converter. I just installed three of them in the last couple months.
Old 02-10-2010 | 11:27 AM
zach24's Avatar
I saw were the the end without the point goes but where does the side with the point go.... can you send a pic since you have bout the same model truck
Old 02-10-2010 | 02:05 PM
It is an aftermarket accessory that converts your GM radio antenna wire to fit into an aftermarket radio. I can't take a picture, but if you look in the back of any aftermarket radio you'll see a hole that takes the side with the point.
bharmon444's Avatar
Do you have an after marker radio or factory ?
Old 02-10-2010 | 07:12 PM
zach24's Avatar
right now i have a factory radio that wont power on for some reason.... would the factory radio not being plugged into the antenna be the reason it isnt turning on? Or i have some of those little colorful chips with the two metal pieces sticking out that are missing could this be another problem? all i realy need to know is why my factory radio isnt working
Old 02-10-2010 | 08:43 PM
I'm thinking that whoever had your truck before you installed an aftermarket radio and before they sold it they took it out. Is your slave deck for cassette's still there? My factory radio is a dummy because I have an aftermarket in place of my slave deck. It's a thought, but I could very well be wrong...
Old 02-11-2010 | 11:02 AM
zach24's Avatar
i believe you are right cause i dont have a casset thing in the slave deck. I do have the the radio thing by the steering wheel but it wont turn on...
Old 02-11-2010 | 07:57 PM
Hmmm. Do you just have a hole in the dash where the Slave deck should be? If so, when you look in there do you see two or three wiring harnesses not hooked up to anything??
Quick Reply: what part is this for?
