What size of tires
Old 08-22-2008 | 09:37 AM
sledhead151's Avatar
Default What size of tires
I was wondering what size of tire will fit on a 2000 Silverado without a lift? Any comments would be much appreciated
Old 08-22-2008 | 10:25 AM
bad2006z71's Avatar
Default RE: What size of tires
probably 285/75/16 would fit no problem
Old 08-22-2008 | 12:13 PM
gpet6669's Avatar
Is it 4x4? 31x10.50 will fit with out any lift and if you want to do a little trimming then you will be able to fit 32x11.50. Thats what I have on my truck, they rub just a little bit on the bumper when I am at a 3/4 turn and the truck is leaning like in a turn. I didn't trim anything on my truck, I just turned up my tortion bars a bit just to get them not to rub all the time. But if you rim it then it should not rub at all.
Good luck on what tires you get, also the rubbing is mainly the width and wheel offset. If you get the right offset you may be able to get away with not trimming anything, just talk to a good wheel and tire shop, and talk to the most experianced guy (or girl!! )in there, not just the salesman.
Dunkan2233
11-18-2009 06:56 PM
kota123
05-27-2009 05:28 PM
adampgasser
01-19-2008 07:38 PM
DezertMachine
12-10-2007 09:45 PM
TrucksNBeer
01-30-2007 01:09 AM
Quick Reply: What size of tires
