wipers & transmission
Old 07-08-2006 | 12:36 PM
gilmerhousedetective's Avatar
Default wipers & transmission
I have a 1994 C1500 Extended Cab with a couple of little problems. First, my wipers do not work properly. The intermittent function does not work and when it does the wipers stay on as if I had selected the low speed. Also, when I turn the switch off, the wipers will continue to operate for some time and eventually will stop - usually in my line of site. Sometimes, I have to jiggle the switch in order to get the wipers to come on at all and the windshield washer pump does not work at all.
Second, my transmission shudders at cruising speed. It stops shuddering when I kick it down. Also, when I try to accelerate gradually the transmission shudders and I have to depress the accelerator in order to downshift the trans. There is also a slight slippage between second and third gear, but stops when the trans heats up or when the a/c is on.
Help.
Old 12-04-2008 | 02:36 AM
rooster1969's Avatar
Default RE: wipers & transmission
Same wiper problem here on one of my 93`s
72charger
8
10-23-2007 07:14 PM
cajunwoodrick
05-17-2007 02:02 PM
ebaron
04-26-2007 10:39 AM
scauntay
01-06-2007 03:49 AM
malecky
11-29-2005 03:13 AM
Quick Reply: wipers & transmission
