Wire
Old 01-20-2010 | 06:48 PM
abram's Avatar
Default Wire
Hello, new here, just joined.
I have a 77 Silverado 2wd c10 that I have redone from the ground up, heres some of the gory details, swapped out the 350 with an bumped up Olds 455, along with a TH400 with shift kit, shaved the door handles off, roll pans front and back, B&M ratchet shifter, put linear actuators on the hood, and well a bunch of stuff, and according to my wife "too much stuff". Bought the truck new when i was a kid and rebought it from a kid 2 years ago and thats when the "too much stuff began". Now the problem i have is after plopping the 455 in and getting it tuned and purring, I have a red or brown colored wire running up the frame on the passenger side that appears to be coming from either the fuel tank cross over witch which runs up the frame to not quite to the engine compartment, and for the life of me i cant figure out where it goes, I have grounded it as well as put power to it but nothing seems to change, the tank switch still works, but the fuel guage is showing way past full and doesnt seem to move, probably a silly fix but it has me stumped, any ideas or thoughts would be great,
Cheers
Al
Old 01-22-2010 | 08:52 AM
tasutt2009's Avatar
Rule of thumb if your fuel gauge stays "above" full is a loss of ground (B-). Usually at the sending unit.
Old 01-22-2010 | 06:43 PM
abram's Avatar
Default sender
I dropped the tank down, now i need to figure out how to get the sender out so I can replace it??????
Thanks
Old 01-22-2010 | 06:51 PM
RUFFNECK4LYFE's Avatar
Remove that retaining ring and the whole assembly comes out.
cubpak89
08-06-2011 04:25 PM
stopspazinout
07-24-2007 04:08 AM
chevyman18
06-16-2007 03:14 PM
velella
08-20-2006 09:18 PM
gruusome
05-24-2006 12:55 AM
Quick Reply: Wire
