wiring question
Old 04-28-2008 | 06:11 PM
thomas's Avatar
Default wiring question
i am trying to put an scytek alarm onto my 87. i have actuators for the doors, but no idea on the best way to wire it. i know for sure i could drill thru the door near the hinge and run it thru the firewall....but that would leave visible wires when you open the door. is there something out there i can buy to not drill thru my door? or any other suggestions?
Old 04-28-2008 | 06:37 PM
rxsteven's Avatar
Default RE: wiring question
You might try running it under the hing in a way it wont get pinched. Im not sure how yours is but you might not be able to see it as much.
Old 04-28-2008 | 06:52 PM
thomas's Avatar
im thinking along the lines of having two plates that can touch each other when the door is shut? or will that not work
Old 04-28-2008 | 09:31 PM
rxsteven's Avatar
Hell yeah if you can get some plate that are reliable go for it. Maybe try radio shack. They use something like that on door alarms for houses. But it might have to be on the outside of the door inside the car.
chrisbmo2000
04-03-2009 07:40 AM
chrisbmo2000
02-03-2009 01:26 PM
chevyrules
27
01-30-2008 04:57 AM
smoke20
15
09-18-2007 07:54 PM
williamcarr03
11-24-2006 09:27 PM
Quick Reply: wiring question
