wiring a third brake light
Old 11-09-2007 | 06:45 PM
stopspazinout's Avatar
Default wiring a third brake light
just picked up a third brake light from a 94-98 model. but mine doesnt have a cargo light or a brake light. wondering how to go about wiring this thing up. should i go through the brake switch and the courtousy lights? any ideas would be good.
Old 11-11-2007 | 05:20 PM
Default RE: wiring a third brake light
bump.
Old 11-11-2007 | 07:26 PM
Argon's Avatar
your gonna have to come off the brake switch and run its own wire...you can't "pick up" the brake signal after the t/s switch,or the chmsl will light when the t/s are on
Old 11-12-2007 | 10:25 AM
ok so run its own wire down to the switch thats on the pedal? and as far as the cargo light whats the best way for that one power from a switch and from the courtousy light circuit to?
Old 11-12-2007 | 03:32 PM
Argon's Avatar
you can come inside and wire it to your courtesy lights...at the dome lamp.
the brake switch..find the wire thats hot when the pedal is depressed....itrs white..i think
Old 11-12-2007 | 05:42 PM
and then just ground the 3rd light to something?
Old 11-12-2007 | 08:18 PM
Argon's Avatar
yes...your dome lamp wiring in the roof has a ground....
Old 11-14-2007 | 05:52 PM
oh ok so to wire up the outer lights just run it into the dome lamp, for the brake light to the switch. and if i want an external cargo light switch just wire that up and jump it into the dome light wiring thats at the light?
Old 11-15-2007 | 07:17 AM
Argon's Avatar
yep..should work....
you'll need a test lite to find which wire gets hot at thr switch..get a somewhat decent test lite...not a dollar one
Old 11-19-2007 | 06:51 PM
well looking at the brake switch the white wire goes down into a splicing with more wires connecting to it. am i correct in assuming this is the hot lead when depressing the pedal?
