wont start
Old 08-03-2007 | 10:49 AM
racethisz71's Avatar
Default RE: wont start
check the fuel pressure in the truck and when it does it check to see if you have spark the crank sensor might be bad
  #32
Old 08-03-2007 | 01:54 PM
Argon's Avatar
Great,72....You'll make it..just watch and learn...and do all the training you can...especially electronics!
  #33
Old 08-05-2007 | 04:02 PM
Cracker's Avatar
Don't drop the tank. Take off the bed. If you get started and begin to think it is more than you can handle you candrive it to a garage, or the parts store for additional tools/parts.
  #34
Old 08-05-2007 | 05:13 PM
kenneybert's Avatar
is taking thebed off easier than dropping the tank ?
  #35
Old 08-05-2007 | 05:34 PM
72charger's Avatar
No. A lot of people with trucks do it that way but if you have never done that and you don't have some people to help you take the bed off I don't suggest doing it this way. Taking the gas tank outis not difficult if you siphon the gas out first.
  #36
Old 08-05-2007 | 08:26 PM
Argon's Avatar
I'd drop the tank..the bead,while fairly simple to remove,is quite heavy.
run out all the gas ya can..an empty tank is nottoo bad...remove the driveshaft.
  #37
Old 08-08-2007 | 08:32 AM
kenneybert's Avatar
fuel pump is changed ,,now its a waiting game to see if that was the culprit ..ill keep y'all informed of the outcome.... next job is putting a snowplow on a 4x4 at least all the hook up for it and getting ready for winter ..thanks for yourwords of wisdom on the pump
  #38
Old 08-08-2007 | 09:23 AM
Argon's Avatar
didja drop the tank?..how did it go?
  #39
Old 08-18-2007 | 10:07 PM
kenneybert's Avatar
yes ,,dropped the tank ...nothing is easy for me ,,, i had help he worked awhile ,i worked awhile, little bit of cussing here and there and throwing a tool or two around ,,,little sweat and knuckle blood and dead skin and hair hanging here and there ..other than that it went pretty smooth i guess ...no wonder a garage wants an arm and a leg and your first born to do stuff .
but thanks for all the info it helped a lot
  #40
Old 08-19-2007 | 07:51 AM
Argon's Avatar
glad its fixed.
yeah,we get 3 hours to change a pump....worth every penny
