Dodge Dakota Forum Discuss the Dodge Dakota here.
99 dakota v8 318 idle issues
Old 09-14-2010 | 02:38 PM
winter ride's Avatar
Default 99 dakota v8 318 idle issues
i first noticed it when driving idle would go up in down , but it also does it while in park.
if idling at 1k it will go up to about 1500 - 1800 rpms then come back down to 1k then back up, the check engine light does come on also. thanks
Old 10-07-2010 | 11:24 AM
RovinAround's Avatar
Codes?
Old 02-24-2011 | 05:57 AM
atul1's Avatar
You will have to do basic checks like spark plugs, replace the spark plug and check whether it is working properly or not. As well check the spark plug wires because these wires sending voltage into spark plug to work properly.
Old 04-03-2011 | 11:07 PM
early93's Avatar
Sounds like either a vaccuum leak or an idle air controller. I had a vaccuum leak on my dakota that raised the rpms at idle to around what I'm guessing is 2000 (mine doesn't have a tach). There's a short 1 1/2 foot or so hose that runs to the idle air controller on the firewall on the pass. Side. That's where mine leaked.
Old 07-05-2012 | 06:51 AM
Robert cena's Avatar
it sounds like either a vaccuum leak or an idle air controller. I had a vaccuum leak on my dakota that raised the rpms at idle to around what I'm guessing is 2000 (mine doesn't have a tach). There's a short 1 1/2 foot or so hose that runs to the idle air controller on the firewall on the pass. Side. That's where mine leaked.
ted14161
05-24-2012 06:01 PM
jbhofc
11-10-2008 11:20 PM
tremont_ram
05-22-2008 01:18 PM
contentsunderpressur
09-07-2007 11:04 PM
winter ride
09-29-2006 03:32 AM
Quick Reply: 99 dakota v8 318 idle issues
