99 RAM LEAF SPRINGS
Old 02-18-2008 | 09:48 AM
RONTEC's Avatar
Default 99 RAM LEAF SPRINGS
[hr]I just put a flat bed on my 99 dodge ram 1/2 ton, and i was wondering if i can put 3/4 ton leaf springs on the rear for a little extra support, for light work. Is this possible with out a bunch of extra work. Will they interchange with each other. Thanks.
Old 05-25-2021 | 01:41 AM
Chuck2500's Avatar
Default Add a leaf ..
Knowing the weight of a flatbed .I hope your running a 10 ply tire.load range e. Swapping out leafs wont work the 3/4 are longer and have larger frame brackets but those could be swapped if youe getting the parts free and can weld sure...but there are cheaper eaiser ways to boost your load capacity.lift blocks bigger wider 10 ply tires .heavy duty shocks.
sean.stewart88
02-28-2012 05:54 PM
matteeeus
05-07-2011 04:04 PM
X-force09
12-28-2009 07:21 PM
Chevycowboy
06-03-2008 11:09 PM
grgrs02
Automotive Parts Wanted
07-04-2007 07:47 PM
Quick Reply: 99 RAM LEAF SPRINGS
