oil pressure gage
Old 10-18-2008 | 02:03 PM
dwhite1957's Avatar
Default oil pressure gage
I have a 94 dodge ram 2500, with auto trans, 5.9l cummins. While driving I noticed my oil gage at 110(maxed out on gage). I also noticed that when I let off the accelerator even a little it would go down to normal. It goes up and down as the truck shifts, how far up depends on how far I push the accelerator. If I put the truck in reverse and back upit stays at normal. If I put the truck in neutral, or park and rev the engine it stays normal.
I also notice that it is actually shifting better than it has. Anyone have ideas?
Thanks
Dave
Old 10-18-2008 | 02:20 PM
js4544x4's Avatar
Default RE: oil pressure gage
dont know dodge but you might have to hook up a different guadge and check it. 110 is kinda high. my jeep will get to 90 on the guadge cold driving . when it is hot its normal.
Old 10-19-2008 | 05:31 PM
dwhite1957's Avatar
I found a ground wire off, reconnected it and the oil pressure problem seems to have been solved. I'll run the trucka few days and let ya know if it works.
Old 11-06-2008 | 07:09 PM
dwhite1957's Avatar
truck is still running ok after I connected theloose ground
acsudberry21
01-18-2012 11:46 AM
guic
08-25-2008 04:25 PM
topknotch06
05-15-2008 01:10 AM
christinia9
12-05-2007 05:23 AM
ldstockwell
12-10-2006 02:41 AM
