passenger side running lights
Old 03-24-2008 | 10:53 AM
bq93's Avatar
Default passenger side running lights
I have a 1996 extended cab 1500 and I’m having a strange wiring problem. I readily admit to being a newbie, but I’m trying.
The problem is I have no park lights on the passenger’s side. Everything else is fine, blinker, brakes, etc., but the right front clearance light and the park lights on the back are a no go. If I pull a trailer the trailer lights are fine. It’s just the park lights on the truck. I’m also having to rely on the “common wiring diagram” from my Haynes manual which isn’t helping me all that much.
I know how to use a tester to see if a wire has power, but I’m having a hard time tracing wires. So where do the wires split into left and right, is that under the driver’s side rear of the bed back by the bumper? Any heads up you can give me as to the wire colors I should be checking? Could it be a switch/fuse/breaker?
I know it sounds simple, but I’m having a heck of a time finding the problem and it’s only a matter of time before I get pulled over.
Any help would be appreciated.
jte52003
02-06-2012 06:42 PM
mike884
Automotive Parts Wanted
01-29-2007 07:01 PM
RRLuck
01-19-2007 09:01 PM
Supacoola16
01-12-2006 10:19 PM
judykevans
08-15-2005 06:51 PM
Quick Reply: passenger side running lights
