Vacumm leaks?
Old 07-24-2006 | 07:20 PM
unclegus's Avatar
Default Vacumm leaks?
Have 1999 2500 4wd with 5.9 gas engine. Started having vacumn leaks. I assume thats what the problem is, cause when you put a load on the engine, the ac vents close. Also gas milage getting worse. Anyone having suggestons give me a holler. Thanks.
Old 08-11-2006 | 02:44 AM
BADAZZ_Dodge's Avatar
Default RE: Vacumm leaks?
its ur check valve on your brake booster, change it, takes 2mins!
Old 08-11-2006 | 02:46 AM
all its doin is losin the vacuum to hold the doors open, it makes the air come through the defrost vents.
Old 08-15-2006 | 02:10 PM
Patrick's Avatar
try checking out dodgeforum.com... lots of good ram info there!
BirdDooHead
01-27-2016 05:04 PM
rjlowe
04-03-2011 10:26 PM
ggwolverine1
8
12-11-2008 12:28 PM
Quick Reply: Vacumm leaks?
