oil pressure 98 dokota 5.2
ok i have repaced the oil pump and bearings when drivin it is about 35 psi but when you stop it drops to 0 and this is pissing me off because if any of you have changed a pump in one of these trucks you would no why
Unless your oil pressure is dropping too low, this is not a problem nor is it unusual. On a cold engine, upon first start-up, the engine goes from 0 oil pressure to a high oil pressure, because the oil is cold and thicker. As the engine and oil heat up, the oil becomes thinner and the pressure goes down. This is normal.
ElectroJoe
08-22-2011 04:21 PM
