Sloppy Rear-Ends in Dakotas?
How much play should there be in the rear axle shafts?
I double-checked the play on the axle flanges and this is what I came up with:
Drivers side: up and down = .008"; in and out .026"
Passenger side: up and down = .008"; in and out .015"
I checked out the wheel bearings and they feel ok. I slid one of the new bearings down onto the journal area where it sits when its installed and surprised with all of the play between the two. I was expecting a nice snug fit but you can wiggle the bearing back and forth on the shaft. Is this a cheap Dakota design or are all bearings of this type like this?
Should I go ahead and change the bearings even if they turn freely and don't feel bad? I need to try and eliminate the howling.
Someone tell me how to go about checking the pinion bearing to see if that is what is causing the noise? I picked up some some Prussian Blue. Give me tip the best way to apply it to the gears? Do I need to have the axles back in to do this or can I pull all of the spider gears out to do the test?
Put a dial indicator on the bottom side of the Ring gear teeth in three places and got .010 backlash, but I didn't have the driveshaft disconnected, just turned the ring gear by hand. Was this the right way to check this?
I am getting a howling noise when giving it gas between 40MPH and 55Mph. it stops when I let off the gas. Coming from behind somewhere. I also am noticing the vehicle shakes noticably when vehicle is under load in Lockup. Any ideas?
JFLS45
02 Dakota 3.9L 4WD 8.25 diff.
JFLS45
havent gone under the car yet, but when I am what makes the rear end feel sloppy? lower a-arm bushings? upper bushings? everything looks ok...but I havent actually gone and inspected fully...just inistalled coilovers but the sway side to side over bumps thing has been going on since winter.but won't completely solve the issue. There is another post about removing the lower mounting/tow bar from the spring pack to soften the ride. I do not recommend doing this.
Worf
11-12-2012 04:26 AM
HighRigger
10-05-2008 12:33 PM
