Dodge/ Ram Heavy Duty Discuss the 2500 and 3500 Heavy Duty Dodge/Ram Pickups as well as the Cummins diesel.
Engine suddenly very loud with slight knock
Old 09-01-2010 | 09:03 AM
longyellowbus's Avatar
Default Engine suddenly very loud with slight knock
Driving home over the weekend, my 96 Ram suddenly got really loud, and started a minor knock. It sounds like engine noise, not exhaust or other usual suspects. The sound itself does not sound like something with a good outcome...
However, I drove home towing a a heavy horse trailer with horses, and did not lose oil pressure or power.
Any thoughts on where to start?
Old 11-30-2010 | 01:18 AM
auto123's Avatar
Those year trucks were real bad about the intermediate shaft getting noisy. That’s the starring coupling under the hood that connects the steering to the gear box. It has to telescope in and out to accommodate the movement of the body to frame movements. If it gets loose, it will rattle. Check with you’re dealer to see if it still has a recall.
Old 02-21-2011 | 02:08 AM
atul1's Avatar
Because of low oil pressure lifters, valve lash adjusters, variable valve train adjuster makes loud noise. kindly check all these things to solve problem
Old 03-01-2011 | 11:16 PM
93Z71's Avatar
if its a cumins turbo deisel there is a dowel pin in the block behind the timing cover that likes to fall out and get slapped around by the timing set and can possibly get jammed in the gears..just a suggestion if you find nothing else to be wrong..did your exhaust fall off ??
Old 07-20-2011 | 01:38 AM
ashleyrms22's Avatar
These problem causes due to low oil pressure lifters,turbo deisel there is a dowel pin in the block behind the timing cover go to your dealer tell the problem or u take it to the company service center. They will solve your problem.
Old 08-23-2012 | 01:34 AM
nelsee's Avatar
Banned
This would be the problem due to the jam in the engine and this would be creating problem.
OntheRoadAgain
8
02-06-2012 06:46 AM
Dreamevil68
09-30-2010 07:10 PM
fretster
01-20-2010 10:41 AM
1996silverado
05-19-2008 02:22 AM
08Z71
12-16-2007 06:00 PM
Quick Reply: Engine suddenly very loud with slight knock
